Show Message/Play Sound
Displays a message box that displays custom text or plays a sound file. For example, you can use this action to display a message and play a sound every time your backup finishes archiving the files.
Tip
The message box displayed by this action has an OK button. You can display a message box with a Yes and No button with the Question Dialog action.
DialogShowMessage
Show Message
Click this check box to display the message box.
Message Text
Enter the text for the message box.
Message Icon
Select the style of the icon for the message box:
Exclamation
DialogShowMessageExclamation
Information
DialogShowMessageInfo
Question
DialogShowMessageQuestion
Error
DialogShowMessageError
Play Sound
Click this check box to play a sound. When you click the check box, you can click the browse button to select a .wav file on the computer.
Test
Click this button to ensure that the parameters for the current action work.
Question Dialog
Open Dialog
Save Dialog
Browse for Folders
Browse for Computers
Input Box
Input Date and Time
Desktop Alert
Choice Dialog
Multichoice Dialog
Custom Input Dialog
Log Dialog
