<< Click to Display Table of Contents >> Navigation: Actions > WebSockets > Connect/Disconnect WebSocket Client |
This action allows to enable or disable the WebSocket client. Please note that this action affects the global configuration of the active WebSocket of the client (see WS Connection manager).
WebSocket Client
Choose the Websocket client from the list. If you edit a network task, the list is not available and you have to enter the client ID manually (see WS Connection manager->Clients->Advanced). If the client ID is incorrect, the action will get an "Invalid WS Client ID" run-time error.
WS Client Manager
You can view or edit lists of registered Websocket servers and clients (see WS Connection Manager).
Action
Choose the action:
•Connect Client
•Disconnect Client
WebSocket Server HTTP Response
WebSocket Server On HTTP Reqest
