<< Click to Display Table of Contents >> Navigation: Actions > Console Application |
This plugin contains actions to automate interactive console applications. For example, cmd.exe, powershell.exe, etc.
Please note that if it is possible to write a script (or batch file) and execute it from the command line, this option is preferable. CMD and POWERSHELL also allow you to execute a previously prepared script from the command line. Look at Run Console Application action
In addition, some console utilities don't allow I/O to be intercepted in interactive mode, which makes such automation impossible.
