<< Click to Display Table of Contents >> Navigation: Actions > Console Application > Close Console Session |
The action closes the console session and the application. You can specify a command to close the application. Typically, these commands are 'exit', 'quit', and 'close'.
Command to close the application
Specify a command to terminate the application. If no command is specified, the action will forcibly close the application with the 'terminate' command.
