<< Click to Display Table of Contents >> Navigation: Actions > Console Application > Read from Console Session |
The action reads the output stream of the console application into a variable. Note that after sending a command, the application must be given some time to output the result of the command. You must insert a pause (100-200 milliseconds or more) or wait for a key phrase to be output before reading (look at the action Wait for Text)
Save output to variable
Enter the name of the variable where you want to save the read value.
Clear output after reading
If you want to clear the output buffer after reading, check this box.
