<< Click to Display Table of Contents >> Navigation: Actions > WebSockets > WebSocket Client Send Message |
The action sends a text message via the specified WS client to the connected WebSocket server
WebSocket Client
Choose the WebSocket client from the list. If you edit a network task, the list is not available and you have to enter the client ID manually (see WS Connection manager->Clients->Advanced). If the client ID is incorrect, the action will get an "Invalid WS Client ID" run-time error.
Text message
The text message you want to send
If client is not connected
If the specified client is not connected at the time the action is called, two execution options are offered:
•Queue message and send it when client is connected again;
•Stop with error
WS Client Manager
You can view or edit lists of registered Websocket servers and clients (see WS Connection Manager).
WebSocket Server HTTP Response
Connect/Disconnect WebSocket Client
WebSocket Server On HTTP Reqest
