<< Click to Display Table of Contents >> Navigation: Several practical recommendations > Control of RoboTask through network > Network Client > Connect to |
Choose the menu item Remote | Connect to for fast connecting to a server. For connecting it is necessary to specify following parameters:
•Computer Name or IP address. It can be also the global network name (for example: www.mydomain.com), if the server is in a global Internet network. One can use the name localhost or the address 127.0.0.1 for access to a local computer (for example, to connect to a local service).
•Port. For example, the port number which is specified on the server. By default, 5500.
•Domain. This parameter is necessary if only the mode of authorization System Administrators is specified on the server. Specify a domain name or "." (Point) for a local user on the server.
•User Name
•Password
Control of RoboTask through neowork
