<< Click to Display Table of Contents >> Navigation: Several practical recommendations > Control of RoboTask through network > Network Client |
Network Client is integrated into the main window of RoboTask. At connection to remote RoboTask, a new branch, fitted to the service tasks, is added on the tree of tasks. Subsequent work with network tasks is completely "transparent". That is, you can trigger, edit, and delete tasks, just as if you would work with local tasks.
RoboTask can open several connections at the same time: one connection on each server. All connections are visible at the tree of tasks.
Control of RoboTask through neowork
