<< Click to Display Table of Contents >> Navigation: Several practical recommendations > Control of RoboTask through network > Network Client > Define connections |
If you need to constantly control the group of servers, you can create predefined connections. At that rate, corresponding items of menu Remote appear and then you can connect to the server “in one click.”
Choose the menu item Remote | Connection manager for creating/editing of predefined connections.
To create a define connection, you need to specify a name of connection for a menu item and then to specify parameters of connection.
If you not switch on the CheckBox "Save Password", RoboTask doesn’t save a password for the next sessions. In this case, when trying to connect, a network client will request a password.
Control of RoboTask through neowork
