<< Click to Display Table of Contents >> Navigation: Menus > Remote > Remote - Connect to |
Connecting to remote RoboTask. It is necessary to fill in the fields in the connection parameters window
Computer Name or IP Address
The name of a computer in a local network or an IP address explicitly. The IP address should be specified according to the IPv4 standard.
Port
The port for connection. On default, the port of the RoboTask server is 5500 for the RoboTask application and 5501 for the RoboTask system service.
Domain
The name of a user domain for authorization. It is used if the network server of RoboTask uses a system authorization. It is necessary to specify the domain name of the server or a dot (.) if a local user of the server is specified.
User Name
Password
The parameters of connecting should correspond to the parameters of the RoboTask network server (see the Server Settings)
The list of predefined connections
