<< Click to Display Table of Contents >> Navigation: Actions > System Functions > Write to Event Log |
The action writes specified message to the System Event Log.
For application mode, the source of the message is the RoboTask Application. For system service mode, the source of the message is the RoboTask Service.
Message Kind
Select the message text from the drop-down list:
•Information message
•Warning message
•Error message
Message Text
Enter the text of the message text as a multi-line text. You can use RoboTask variables in the text.
