<< Click to Display Table of Contents >> Navigation: Menus > Tools > Tools - Enable Automation |
If this option is cleared, the tasks will not run automatically, i.e. all your tasks are disabled. You may run tasks only manually.
Tools - Enable All Tasks in List
Tools - Disable All Tasks in List
Tools - Start selected tasks sequentially
Tools - Backup application tasks
Tools - Restore application tasks
