<< Click to Display Table of Contents >> Navigation: Menus > Tools > Tools - Restore application tasks |
Restoring tasks consists in unpacking tasks from a backup file into the tasks folder.
Restoration occurs with the help of a predefined task launched in the environment of runtime module.
Restore tasks from file
Select backup ZIP file
Overwrite existing tasks
If you want to overwrite existing tasks, then enable this checkbox.
Overwrite existing task tree
If you want to overwrite an existing task tree, then enable this checkbox.
Read log on completion
Check this box if you want to read the task execution log.
Tools - Enable All Tasks in List
Tools - Disable All Tasks in List
Tools - Start selected tasks sequentially
Tools - Backup application tasks
