<< Click to Display Table of Contents >> Navigation: Menus > Tools > Tools - Enable All Tasks in List |
Enables all tasks that are listed in the current task folder. To enable one task, double-click it and, in the appeared dialog window, select the Active check box and click OK.
Tools - Disable All Tasks in List
Tools - Start selected tasks sequentially
Tools - Backup application tasks
Tools - Restore application tasks
