<< Click to Display Table of Contents >> Navigation: Menus > Tools > Tools - Backup application tasks |
Backing up tasks consists of packing the current set of tasks into a ZIP archive. If necessary, it is possible to restore tasks from a saved archive.
Backup is performed using a predefined task launched in the environment of runtime module.
Backup folder
Select a folder to save the backup files. The default folder is in the user profile:
C:\Users\<User_Name>\RoboTaskBackup
If necessary, you can select another folder. The selected folder is saved for future work sessions.
The archive file name is generated automatically using the current date and time:
RoboTask-App-Tasks-YYYYMMDD-hhmm.zip
where YYYYMMDD – date in "YYYYMMDD" format
Read log on completion
Check this box if you want to read the task execution log.
Tools - Enable All Tasks in List
Tools - Disable All Tasks in List
Tools - Start selected tasks sequentially
Tools - Restore application tasks
