<< Click to Display Table of Contents >> Navigation: Actions > SFTP (SSH FTP) > SFTP Upload |
The action allows to upload files and folders from a local disc to the SFTP server.
Local File or Folder
Specify the name of a file or folder which is necessary to upload from a local disc to a server. If a folder is specified, the action uploads all files from the local folder.
Remote Folder
Specify a folder on SFTP server where it is necessary to upload the file or the folder from a local disc.
Recursively fetch a directory (if a source is a directory)
Switch on this parameter if you want to upload the whole folder with all subdirectories. This parameter makes sense only if a folder is specified as a source. If a source is a file, the parameter is ignored.
This mode is similar to SFTP Synchronization action.
If a destination file exists (if a source is a file)
This parameter makes sense only if a file is specified as a source. There are 2 alternatives:
•Rename – if such file exists, it will be renamed when downloading. In this case, the existent file will be saved.
•Overwrite – a file will be downloaded with an original name. If such file exists, it will be overwritten.
