<< Click to Display Table of Contents >> Navigation: Actions > SFTP (SSH FTP) > SFTP Rename File of Folder |
The action allows to rename a file or a folder on the SFTP server.
Old File Name (or Directory Name)
Specify the name of the file or the folder which are necessary to rename.
New File Name (or Directory Name)
Specify a new name of the file or the folder.
Usage:
It is possible to rename separate files/folders:
OldFile.txt -> NewFile.txt
OldFile.txt -> SubFolder/NewFile.txt
It is possible to move one or several files to another folder. For this it is necessary to specify the file names separated by a space and, in the capacity of a new file name, the name of the folder which the files have to be moved into.
File1.txt File2.txt -> /home/user/newfolder
