<< Click to Display Table of Contents >> Navigation: Actions > SFTP (SSH FTP) > SFTP Change Folder |
The action changes the current work folder on the server.
Remote folder
Specify a new work folder. It is possible to specify the folder from the root or current folder. For example:
/home/user/test
test/subfolder
It is possible to get the current folder during (as a result of) the action SFTP PWD.
