<< Click to Display Table of Contents >> Navigation: Actions > SFTP (SSH FTP) > SFTP Command |
The action allows to perform a arbitrary SFTP command and save the result of performing into a variable.
SFTP command
Specify any SFTP command. For example, the command help.
Save Response to Variable
Specify the name of the variable, into which it is necessary to save the result of command performing as a text.
Variable name can be empty. In this case the text of the result will be ignored.
