<< Click to Display Table of Contents >> Navigation: Actions > SFTP (SSH FTP) > SFTP PWD (print working directory) |
Allows you to print the current directory on the remote computer.
This action saves the task log to the current directory on the SFTP server. Also, you can assign the current directory to a custom variable for future use.
Assign Remote Folder to Variable
If you want to assign the name of the current FTP directory to a custom variable, select this checkbox and type the name of the variable in the field below.
