<< Click to Display Table of Contents >> Navigation: Actions > INI files > INI write value |
Saves the value of a single parameter in a specified INI file.
General
INI file name
The full path to the file or file name in the current folder (please see Set Current Folder action).
INI section
The name of a section. If absolute path is given in file name and file exists, can be selected existing name from dropdown list.
Value name
Parameter name. If absolute path is given in file name and file exists, can be selected existing name from dropdown list.
Write value
Enter the value to write.
Advanced
Use the specified line separator
The separator string to use when saving multi-line values is {eol} by default.
The INI file name, INI section, Value name fields can contain both absolute values and variables that will be replaced by its value when the action is performed.
The {V} button.
Allows you to select a system or user variable to insert into the current field.
