<< Click to Display Table of Contents >> Navigation: Actions > INI files > INI delete section |
Removes the specified section from the INI file. All parameters from the section will also be deleted.
INI file name
The full path to the file or file name in the current folder (please see Set Current Folder action).
INI section
The name of a section. If absolute path is given in file name and file exists, can be selected existing name from dropdown list.
