<< Click to Display Table of Contents >> Navigation: Actions > INI files > INI delete value |
Deletes the specified parameter from an INI file.
INI file name
The full path to the file or file name in the current folder (please see Set Current Folder action).
INI section
The name of a section. If absolute path is given in file name and file exists, can be selected existing name from dropdown list.
Value name
Parameter name. If absolute path is given in file name and file exists, can be selected existing name from dropdown list.
