<< Click to Display Table of Contents >> Navigation: Actions > RoboTask Commands > Backup Tasks |
This action backs up your tasks. This action is similar to the Backup Tasks option in the main menu of the application.
The action allows you to include backup in your task and ensure that your tasks are automatically saved on a schedule you like or as tasks are changed and added.
The action packs all tasks and the tasks tree into a ZIP file. The file name is formed in the format
•For application mode: RoboTask-App-Tasks-YYYYYYMMDD.zip
•For system service mode: RoboTask-Service-Tasks-YYYYYYMMDD.zip
YYYYYYMMDD - is the current date in this format.
Please note that restoring from backup is possible only in manual mode from the main menu of the application
Backup folder
Specify a folder for creating backups.
