Navigation: Actions > RoboTask Commands >
The action clears the task log. No additional parameters are required.
Minimize RoboTask
Restore RoboTask
Exit RoboTask
Enable Automation
Disable Automation
Log Message
Restart RoboTask
Set task Log Level
Clear task log
