Search for Files --> Exclude folders
Hey Oleg,
With the Search for Files option, we wanted to clean a folder of its contents (including subdirectories), all files older than 1 month. That works ofcourse ;) However, there are 2 subfolders which should not be emptied.
In the "Exclude masks", I've tried to exclude the complete path, the name of the folder, even this method, but it doesn't work.
See screenshot with just 1 example of the exclude which I've tried. The red folders (including files) should be kept, regardless the age of the files. The green ones and the files in the root are allowed to be deleted.
Can you adivse me in this, or....am I missing something?
Re: Search for Files --> Exlude folders
...the name of the folder, even this method, but it doesn't work.
Unfortunately Search for Files action has not such mechanism now. I wrote this in our ToDo list.
Now you can solve the problem like in my example (see below)
CatID=INTEGER|0
ExternalName=STRING|"Task1491"
ID=INTEGER|715728214
Name=STRING|"List of files without several subfolders"
StepPause=INTEGER|0
Name=STRING|"Set variable ""Folder"" with value ""c:\temp"""
_rt_variables_produced=STRING|"Folder"
varname=STRING|"Folder"
varvalue=STRING|"c:\temp"
Name=STRING|"Create File List (variable: List1) //wihout subfolders"
_rt_variables_produced=STRING|"List1"
After=STRING|"0"
aftercount=STRING|"0"
AfterLine=STRING|"0"
Before=STRING|"0"
beforecount=STRING|"0"
BeforeLine=STRING|"0"
date1=STRING|"20240410"
date2=STRING|"20240410"
destvar=STRING|"List1"
DuringMinutes=STRING|"1"
file0=STRING|"{Folder}\*.*"
savetofile=STRING|"0"
savetovar=STRING|"1"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"0"
Name=STRING|"Create File List (variable: List2) //necessary subfolder"
_rt_variables_produced=STRING|"List2"
After=STRING|"0"
Before=STRING|"0"
destvar=STRING|"List2"
file0=STRING|"{Folder}\MP4\*.*"
file1=STRING|"{Folder}\MXF\*.*"
file2=STRING|"{Folder}\SocialMedia\*.*"
filecount=STRING|"3"
sort=STRING|"0"
sortby=STRING|"0"
subdirs=STRING|"1"
ActionID=STRING|"A_STR_TRIM"
Name=STRING|"STR Trim"
custom=STRING|"0"
eol=STRING|"1"
lead=STRING|"1"
source=STRING|"{List1}"
spaces=STRING|"1"
tabs=STRING|"1"
trailing=STRING|"1"
variable=STRING|"List1"
custom=STRING|"0"
eol=STRING|"1"
lead=STRING|"1"
source=STRING|"{List2}"
spaces=STRING|"1"
tabs=STRING|"1"
trailing=STRING|"1"
variable=STRING|"List2"
Name=STRING|"Show Text"
autoclose=STRING|"0"
fromfile=STRING|"1"
line00000000=STRING|"{List1}"
line00000001=STRING|"{List2}"
linecount=STRING|"2"
timeout=STRING|"10"
Re: Search for Files --> Exclude folders
Yupz, it works. Thanks!
