How do I exclude a folder.
BrianSmith
Post by BrianSmith »
How do I exclude a sub folder and all files within this folder when using the Pack Files task.
In the exclude mask field I tried entering the full path to a sub folder under the folder I was packing but it still packed files in that folder.
Example:
Files to Zip: c:\temp\*.*
Exclude Mask: c:\temp\folder1\*.*
c:\temp\folder1 contains more sub folders and files but the task seems to get all of these folders and files and zip them as well.
How do I prevent any file or folder in c:\temp\folder1 from being zipped?
What is the exclude mask?
AlexeySurkis
Post by AlexeySurkis »
By using the "exclude mask" option, you can tell the action what files you don't want to pack.
Example:
*.bak
*.txt, test??.*
Regarding how to exclude entire subfolders - we've put this idea to our TO-DO list.
You may specify in "Exclude masks" masks with folders separated by commas. Like this:
"c:\temp\folder1\*.*","c:\temp\folder2\*.*"
For example see the Task below:
; RoboTask Task file
; Do not edit!
CatID=INTEGER|1807969784
ExternalName=STRING|"Task86"
ID=INTEGER|390957533
Name=STRING|"Pack Files except some folders"
Name=STRING|"Show ""This task backup ""C:\Temp"" folder with subfolders"""
msg0=STRING|"This task backup ""C:\Temp"" folder with subfolders"
msg1=STRING|"(except forlders  ""C:\Temp\dst"" and ""C:\Temp\src"")"
msg2=STRING|"and save into ""C:\MyBackup.zip"""
msgcount=STRING|"3"
Name=STRING|"Change Folder (C:\temp)"
folder=STRING|"C:\temp"
ActionID=STRING|"A_ZIP_PACK"
Name=STRING|"Pack Files"
action=STRING|"0"
coment0=STRING|"{DateTime}, {DayOfWeek}"
coment1=STRING|"This zip-archive created by RoboTask (C) 2003-2004 Neowise"
comentcount=STRING|"2"
compreslevel=STRING|"1"
destfile=STRING|"C:\MyBackup.zip"
dosformat=STRING|"0"
exclude=STRING|"dst\*.*,src\*.*"
file0=STRING|"*.*"
includesubfolders=STRING|"1"
incsysandhidden=STRING|"0"
junkdirnames=STRING|"0"
password=STRING|"2591325706251962622642913"
BrianSmith
Thanks for the feedback.
I have gone with using a custom built RoboTask that uses the WinRAR command line application to compress files.
I have posted this RoboTask earlier on the forum.
