<< Click to Display Table of Contents >> Navigation: Several practical recommendations > Using Variables in Tasks > StartTaskCause local variable |
Each task during execution contains a local variable containing information about the reason for starting the task. The information is a JSON string.
Below are examples, for convenience in a readable form:
"computerName":"",
"description":"Tray Icon",
"name":"trigger",
"remote":"False",
"taskId":"",
"triggerId":"E_GENERAL_TRAYICON"
"computerName":"",
"description":"Run other Task for test",
"name":"task",
"remote":"False",
"taskId":"3B4E6251",
"triggerId":""
To extract a specific JSON field, you can use expressions like these (see using prefixes):
•{json:StartTaskCause.name}
•{json:StartTaskCause.taskId}
•etc.
Field descriptions
•computerName – the name of the computer from which the task was launched. This field will only be filled in if the task was launched remotely from a network connection. If the task was launched locally from the same RoboTask instance, this field will be empty.
•description – a description of the reason as you see it in the RoboTask system log.
•name – the actual reason for starting the task. This field can take the following values:
omanual – manual start from the RoboTask main window
otask – start from another task. In this case, the taskId field will contain the ID of the parent task in hexadecimal format.
otrigger – task launched by a trigger. In this case, the trigger type will be recorded in the triggerId field.
ocom – task launched from a built-in COM object (see RoboTaskApp object). This is essentially launching a task from an external script or application using the RoboTask COM interface.
oruntime – task launch in runtime module (see Runtime module).
oerror-handler – task launch as an error handler. The taskId field will contain the ID of the task in which the error occurred and the error handler was launched.
orestserver – task launched from the built-in REST server. (see REST API settings)
odebugger – task launched in the debugger.
ocommand-line – task launched from the command line using the RTaskRun.exe utility
•remote – logical value. True – launch from a remote RoboTask via a network connection. In this case, the computerName field will be filled in. False – local launch. The computerName field will be empty.
•taskId – parent task ID in 16-digit format. This field will not be empty if the task is launched:
ofrom another task locally
ofrom a remote task via a network connection
othe task is launched as an error handler
In other cases, this field will be empty.
•triggerId – trigger ID if the task is launched by a trigger. In other cases, this field will be empty.
Saving of a result into a variable
Rules for using variables in expressions
How to use variables correctly
