<< Click to Display Table of Contents >> Navigation: Actions > Excel > Excel Save Document |
This action saves the changed document in the disk. If you need to save the changing in a file, use this action without fail. The automatic saving does not occurs when a task ends or a document is closed.
This action does not demand additional settings and saves the file with the name which is specified in the action Excel Open Document.
