Check for Window
Navigation:  Actions > Window >
Check for Window
Checks to see if a window exists or is active. For example, you might want to create a task that starts your HotSync Manager for your Palm PDA every day and synchronizes the Palm device data with Outlook. You might want to check for the existence of the HotSync Manager window to ensure that it has started.
WindowCheck
Window Caption
Select the name of the window from the dropdown list. The contents of this list vary with the applications currently launched on your computer.
Caption Must Match Exactly
Click the check box to check only windows that match the entire window caption. If this check box is clear, the action checks for windows that partially match the caption.
Window Class.
Select Window on the Screen.
When pressing this button, you turn on the mechanism of selection a window on the screen. When you move the mouse pointer, the window recognized by RoboTask are displayed in the information window in the top-left or top-right corner of the primary display. Meanwhile, you can use the mouse to perform some actions. To select the necessary window, press CTRL. To cancel - press ESC. When selecting a window, the fields Window Caption and Window Class are filled in automatically.
Watch hidden windows – select this checkbox if you want the action to monitor hidden windows.
Watch child windows – select this checkbox if you want the action to monitor child windows. As a rule, these windows are dialog boxes and secondary windows opened by Windows applications.
Check For
Select one of the following options to check for existing windows or windows that are open.
Window Exist
Window Active
Abort Task If
Stops task executing according with selected option:
Window Not Exists/Active - stops the task if the window does not exist or is not active.
Window Exist/Active - stops the task if the window exists or is active.
Window Command
Wait for Window
Window Size and Position
Window Elements Loop
Window Get Size and Position
Terminate Process by Window
