Questions about "Choice Dialog"
robotask813
Post by robotask813 »
When unchecking the "Use Unicode UTF-8..." box in Control Panel->Region->Management Tab->Current Language for Non-Unicode Programs, the following situation occurs.
一、Actions: "Choice Dialog", the number of Chinese characters entered (Even numbers: "变量", singular: "变", Chinese punctuation marks are also counted as 1 Chinese character)
1. The following can run normally (Even numbers Chinese characters: “变量”)
robotask813
Re: Questions about "Choice Dialog"
2. The following are the situations where errors can occur (odd Chinese characters: “变”)
robotask813
3. The following are the situations where errors can occur (odd Chinese characters: “变”)
robotask813
4. The following are the situations where errors can occur (Chinese punctuation is also counted as 1 Chinese character: “、”)
The following is 1 Chinese punctuation mark + 2 Chinese characters
robotask813
The following is 1 Chinese punctuation mark + 3 Chinese characters
This case works fine.
When unchecking the "Use Unicode UTF-8..." box in Control Panel->...
This is the same problem as in the Input box dialog.
These dialogs has similar algorithm.
