Questions about "Actions:Input Box"
robotask813
Post by robotask813 »
The following are the issues that arose during the trial:
Questions about "Actions:Input Box"as follows:
1. Assign Entered Value to Variable : Variables written will automatically become uppercase
2. "Task name":An error will occur when there are too many Chinese characters(More than 26 different Chinese characters,),Log prompt error:"An error occurred"or "Aborted"("Input Box" :The following "Actions" will not be executed)
3. "Actions:Input Box":
"Prompt String":An error will occur when there are too many Chinese characters(More than 26 different Chinese characters,),Log prompt error:"An error occurred"or "Aborted"("Input Box" :The following "Actions" will not be executed)
If problems 2 and 3 above occur at the same time or separately, the errors will be random(Log prompt error:"An error occurred"or "Aborted").
Re: Questions about "Actions:Input Box"
Variable names are case-insensitive,
so the names MyVar, myvar, and MYVAR are all the same name.
Could you give me some examples of Chinese strings that you want to use? I want to check it myself.
robotask813
1. "Task name"
2. "Actions:Input Box":“Prompt String”:
3. When the Task is running, in the "Input Box" dialog box, it is normal to enter an even number of Chinese characters, but it is terminated when an odd number of Chinese characters are entered. The action after "Actions: Input Box" will not be executed, and the run log prompts "Aborted"
Above 1~3,If you enter Chinese characters in these three positions, as long as one Chinese character is an odd number, an error will occur. If it is an even number, it will be normal.
CatID=INTEGER|976845217
ExternalName=STRING|"Task128"
ID=INTEGER|1122542263
Name=STRING|"变量"
StepPause=INTEGER|0
Name=STRING|"Input Box"
_rt_variables_produced=STRING|"KK"
password=STRING|"0"
prompt=STRING|"变量"
stopifcancel=STRING|"1"
variable=STRING|"KK"
Name=STRING|"Show ""ok"""
msg0=STRING|"ok"
I've tried your task. It works.
I try to enter the string
對話框要求我輸入一長串文字。我不知道該輸入多少。我們再試一次。
Give me some strings when you get an error.
I don't know Chinese, so I use Google Translate.
I made small modification of your task
CatID=INTEGER|307868550
ExternalName=STRING|"Task1568"
Name=STRING|"变量"
StepPause=INTEGER|0
password=STRING|"0"
prompt=STRING|"变量"
Name=STRING|"Log message (neutral) ""{KK}"""
expression=STRING|"3"
message=STRING|"{KK}"
mode=STRING|"0"
Name=STRING|"Show ""{KK}"""
msg0=STRING|"{KK}"
msg1=STRING|"ok"
msgcount=STRING|"2"
robotask813
Please see my demo: I use your code to demonstrate
1. "Input Box", the number of Chinese characters entered (even: "variable", odd: "change")
I downloaded your source code without making any changes, as follows:
If you run it directly, the task can be started normally. Please see what I entered: “变量”
1. First demonstrate how it can be run normally: the input content is 2 Chinese characters: “变量”
I'm sorry I don't see your images
robotask813
2. Now run the problematic method: the input content is 1 Chinese character: “变”
The action behind "input Box" did not run and the error "Aborted" occurred.
robotask813
3. Now run the problematic method: the input content of "Prompt String" is 1 Chinese character: “变”
Summary: "Input Box", "Prompt String" and Task name: The input content in these three positions is 2 Chinese characters (such as "variable"), which can run normally. If the input content is 1 Chinese character (such as "change"), problems will occur.
Huadan: You can try adding English characters after the Chinese characters when an error occurs, and you will make new discoveries.
I made a several tests on the test machine
I set the language for non-Unicode programs to Chinese (Traditional, Hong Kong SAR)
Control panel->Region->Administrative tab ->current language for non-Unicode programs (see screenshot)
If you have checked the "Use Unicode UTF-8..." box, the task will work correctly with any strings.
If you uncheck this box, the task will encounter the same problems you described.
In any case, we will investigate the problem. Thank you for the information.
The problem is already fixed in version 10.6
Update your copy
