Hotkey Triggers only when Specific Application is Active
DH_ND4C
Post by DH_ND4C »
Is there a way (that I am overlooking) to only have hotkey triggers function when a specific application or window is in focus?
I imagine as I build more tasks with unique hotkey triggers, things might get messy with conflicts in various applications.
My thought was to add a step to "check for window" that stops the task if needed.
Is this the correct way to go about it?
Re: Hotkey Triggers only when Specific Application is Active
You can put Check for window into the task and stop the task if necessary window is not active.
Hot-key trigger set the global system hot key
