RoboTask 8.5 has been released
New version of RoboTask is ready for download. Download and try RoboTask 8.5 now
What's new in RoboTask 8.5:
Legend
[+] Feature added
[-] Bug fixed
[*] Modified or improved[/i]
+ New plugin "Remote Task" for automated task management on a remote RoboTask
instance. New actions:
+ Remote Task Connect
+ Remote Task Disconnect
+ Enable/Disable Remote Task
+ Start Remote Task
+ Stop Remote Task
+ Wait for Remote Task
+ Remote Task Status
+ Active Connections Loop
+ Optimized GUI for High DPI monitors
* Some improvements to the main application window.
* Many other small optimizations, improvements and bug fixes.
Please note that Basic Plugin is available for x32-bit edition only.
This plugin is deprecated. You can use Script tools instead
