<< Click to Display Table of Contents >> Navigation: Actions > Script tools > Script extesions |
The RoboTask gives some extensions of the language (for VB Script and JS Script): several additional functions. You can use this functions freely in your texts of scripts. Notice that the JavaScript is case sensitive. But the functions of extensions work insensitive to a using register. Thereby, the expressions
LogMessage("Hello World!!!");
logmessage("Hello World!!!");
are identical.
function LogMessage(AMessage)
The function outputs a message to a log. In edit mode of a script, the function outputs a message to the log of the editor. When a task works, a message is output to a log of the task in the mode User Message.
AMessage - the string to output
function include(ScriptFileName)
This function returns the text of specified script file.
ScriptFileName – The name of file which is necessary to load.
You can execute this text in your script. Just put these into you script:
for VB Script action use
execute include("d:\myscripts\script.txt")
For JS Script action use
eval(include("d:\\myscripts\\script.txt"));
function Pause(AMilliseconds)
Pauses and stops execution of the script for the specified time.
AMilliseconds - pause time in milliseconds.
function Messagebox(AMessage)
Displays a dialog box with the specified message
AMessage - the message as a string
function RoboTaskApp()
This function returns the COM object RoboTask. This object allows to use some functions of the RoboTask directly from a script. The description of the object is in the chapter "RoboTaskApp Object".
