<< Click to Display Table of Contents >> Navigation: Actions > Script tools > Python Script > RoboTask object for Python |
RoboTask object is similar in functionality to the built-in COM object RoboTaskApp, but there are major differences. Please note that Python is case-sensitive.
Here is an example of how to use the object:
from robotask import *
rt = RoboTask()
print(rt.version)
print(rt.version['plain'])
The basic Python package doesn't contain a Windows COM object support module. However, you can use your Python with pywin32 support (see here) and use the RoboTaskApp object directly. Code example:
import win32com.client as win32
rt = win32.Dispatch('RoboTask.App')
print(rt.Version)
print(rt.TaskCount)
RoboTask()
Constructor.
Creates RoboTask object.
Use:
rt = RoboTask()
version
Property.
Returns dictionary with fields:
plain - RoboTask text version. For example, "8.3"
major - major version (8)
minor - minor version (3)
task_count
Property.
Returns the number of registered tasks in RoboTask.
expand_text(text)
Method.
Expands a string containing RoboTask variables and returns it.
For example, expression
rt.expand_text('Date and time now: {DateTimeToFormat({DateTime},yyyyy-mm-dd hh:nn:ss)}')
Will return a value like this:
Date and time now: 2021-04-01 17:57:35
log(text)
Method.
Outputs the specified text to the task log in user message mode.
log_info(text)
Method.
Outputs the specified text in the log in system message mode.
log_warning(text)
Method.
Outputs the specified text in the log in warning mode.
log_error(text)
Method.
Outputs the specified text to the task log in error message mode
add_user_var(name, value)
Method.
Creates RoboTask variable with NAME name and VALUE value.
set_user_var(name, value)
Method.
Sets the VALUE to RoboTask variable with name NAME.
del_user_var(name)
Method.
Deletes RoboTask variable named NAME.
task_info(num)
Method.
Returns task information by number or name (external name).
Method returns dictionary with fields:
•name - task name (title).
•ext_name - external name. You can use this name to refer to the task in the script
•enabled - True or False
•state - task state. Can have 5 values:
manual - the task has no triggering events, or its triggering events are disabled (see the enabled property). It waits to be run manually or from another task;
idle - the task has some enabled triggering events. It waits to be run automatically,
disabled - the task is disabled while editing,
running - the task is started and in progress,
stopped - the task received the stop command, but it is yet running. After the task is completely stopped, its status becomes either "manual" or "idle".
current_task()
Method.
Returns information about the current task.
The result is exactly the same as task_info method except that it returns information about the current task.
start_task(ext_name, params = '')
Method.
Start task by number or External Name.
Parameters
•ext_name - task number or external name
•params - parameters of the task to be launched. Empty string by default. Parameters can be set as text, one parameter per line :
parameter_name=parameter_value
stop_task(ext_name)
Method.
Stops task with a specified number or External Name
Note that RoboTask only sends a signal to stop the task. The task will stop when the step that is currently in progress is completed.
enable_task(ext_name)
Method.
Changes task state by number or External Name to "enabled" and starts all "enabled" task triggers.
disable_task(ext_name)
Method
Changes task state by number or External Name to "disabled" and stops all active task triggers.
service_mode
Property
Returns logical value.
True - RoboTask is running in service mode.
False - RoboTask is running in normal app mode.
window_handle
Property
Returns the RoboTask's window handle that receives system messages.
