<< Click to Display Table of Contents >> Navigation: Several practical recommendations > Running RoboTask as an NT service > Peculiarities of working in the system service mode > Peculiarities of RoboTask Service working in RDC mode |
In RDC (Remote Desktop Connection) mode you can't see the green icon. The system prohibits the interaction of service with desktop in RDC regardless of the settings of service. You can see the green icon and the main window of RoboTask only in the local session (i. e. from the local terminal).
But Windows 2003 Server gives an opportunity to intercept the local session for RDC. It is necessary for it to start up the client RDC with the parameter /admin.
The command line is:
%SystemRoot%\system32\mstsc.exe /admin
To know about the possible parameters you should implement the command:
%SystemRoot%\system32\mstsc.exe /?
The visual differences between the work in ordinary application mode and in the system service mode
Peculiarities of work RoboTask Service under OC Vista/ Windows 7/ Windows 2008 Server
How to get an access RoboTask Service
