<< Click to Display Table of Contents >> Navigation: Actions > Sound Volume > Get Sound Volume |
The action allows retrieving current sound volume level and saving it in variable. The value is the integer number from 0 up to 100.
Get Sound Volume to Variable (0 .. 100)
Specify the variable name where you want to save the result.
