<< Click to Display Table of Contents >> Navigation: Actions > Sound Volume > Get Mute Status |
The action retrieves the mute status and saves the logical value to variable.
True – mute is ON
False – mute is OFF
Get Mute Status (TRUE or FALSE)
Specify the variable name where you want to save the result.
