<< Click to Display Table of Contents >> Navigation: Actions > Variables > Count array elements |
This action is designed to count elements in comma-separated string or JSON array. This is convenient for looping over elements if the number of elements is not known in advance.
Source string
The string in which to count the number of elements. Available formats:
•Standard comma-separated string
•JSON array
Process string as...
Specify the processing mode for the source string.
Save number of elements to variable
Enter the variable name in which to store the number of elements.
If you have selected the Comma-separated string array type, you need to specify the string format:
•Delimiter
•Quote char
•Strict delimiter
Please note that if you do not use the Strict Delimiter mode, the action will also consider spaces outside quotation marks as delimiters.
The default format is used:
•Delimiter = Comma (,)
•Quote char = Double quotation mark (")
•Strict delimiter = FALSE
