Beginner HELP
nwinc
Beginner HELP
Post by nwinc »
Im completely new to this, but the program is user frienly and I can easily see the multitude of uses I can apply for my business and personal use.  The problem is there is no entry level how to for what I need aside form the experimentation of the program itself.  Ie:  I can find out to copy paste files.  I can find how to set a trigger for the event.  I can find how to run the demo to find the newest files.  What I cant figure out is how to combine those tasks.  If I could see the events combined once I could probably understand the technique for such things at that point.  IE:  A trigger that monitors a folder for new files or file changes, then copies only the changed file to another location via the trigger.   I feel like im all over it but cant get the right combination in the right places.  Could someone create this form me or offer a how to suggestion.
Beginner HELP
"File monitor" trigger can save the list of changed files into text file. Next, you can process this list in started task in the Text loop.
You can copy/move files or do something else.
