filter doubles in CSV
rice1973
Post by rice1973 »
Hi,Can i filter out doubles lines in a CSV by filtering in a certain column?Example; "3743","187.80.037","Terral","010037420110","20","99.95","99 .95" "3743","187.80.037","Terral","010037420110","20","99.95","99 .95" "3743","187.80.037","Terral","010037420110","20","99.95","99 .95" "3743","187.80.037","Terral","010037420110","20","99.95","99 .95"Can that be filtered on the first column, "3743"? Result should be only one line; "3743","187.80.037","Terral","010037420110","20","99.95","99 .95"
Are repetitive lines going in succession?
You are forgetting that CSV is only text file and you can't apply SQL expression features.
But if the lines are going in succession I think that it's possible to do something.
rice1973
Post by rice1973 »
Hi,There a a few differences in the lines i only pasted the first 7 columns, i cannot change this in the SQL query. I need this done in the textfile.
See the example below, please.
The task converts file C:\incoming\1.csv to C:\incoming\2.csv and remove all repetitive rows (by 1-st column, of course)
CatID=INTEGER|1380072790
ExternalName=STRING|"Task943"
ID=INTEGER|1152474621
LocalVariables=STRING|"OLDVALUES,c_line,new_text"
Name=STRING|"""Distinct rows"" in CSV file"
Name=STRING|"Set variable ""OLDVALUES"" with value """""
varname=STRING|"OLDVALUES"
Name=STRING|"Show ""{NEWTEXT}"""
msg0=STRING|"{NEWTEXT}"
Name=STRING|"Show ""{OLDVALUES}"""
msg0=STRING|"{OLDVALUES}"
Name=STRING|"Set variable ""NEWTEXT"" with value """""
varname=STRING|"NEWTEXT"
Name=STRING|"Text Loop"
destvar=STRING|"C_LINE"
file=STRING|"C:\incoming\1.csv"
linecount=STRING|"0"
sourcetext=STRING|"0"
operator=STRING|"9"
value1=STRING|"{c_line(0)}"
value2=STRING|"{oldvalues}"
Name=STRING|"Set variable ""NEWTEXT"" with value ""{NEWTEXT}{C_LINE}{EOL}"""
varvalue=STRING|"{NEWTEXT}{C_LINE}{EOL}"
Name=STRING|"Set variable ""OLDVALUES"" with value ""{oldvalues}{C_LINE(0)}{EOL}"""
varvalue=STRING|"{oldvalues}{C_LINE(0)}{EOL}"
Name=STRING|"Create text file C:\incoming\2.csv"
fileexists=STRING|"0"
filname=STRING|"C:\incoming\2.csv"
line0=STRING|"{newtext}"
suppress=STRING|"0"
rice1973
Post by rice1973 »
Hi,Almost ok.. After the task al the lines appear in the file is one big chuck of text.The end of each line is now an "enter". This is now gone. So there is no layout anymore.p.s. i can ad an "end"symbol to each line wich you can filter on if that is easier?Please advice.......
See my task, please.
It adds end-of-line symbols ({EOL}) at the end of each line.
Also I have looked at my test files. Everything is OK.
It's an ordinary text files
rice1973
Post by rice1973 »
Hi,Checked again.. Still not working? Don't know why.Can i email you the CSV? So that you can take a look?ps; In the file are more then 1 double line.Example;"3743","187.80.037","Terral","010037420110","20","99.95","99 .95""3743","187.80.037","Terral","010037420110","20","99.95","99 .95""3743","187.80.037","Terral","010037420110","20","99.95","99 .95""3743","187.80.037","Terral","010037420110","20","99.95","99 .95""3745","188.11.303","Nice","010037420115","10","29.95","20 .95""3745","188.11.303","Nice","010037420115","10","29.95","20 .95""3745","188.11.303","Nice","010037420115","10","29.95","20 .95""3745","188.11.303","Nice","010037420115","10","29.95","20 .95""3745","188.11.303","Nice","010037420115","10","29.95","20 .95""3745","188.11.303","Nice","010037420115","10","29.95","20 .95""3745","188.11.303","Nice","010037420115","10","29.95","20 .95"Should output;"3743","187.80.037","Terral","010037420110","20","99.95","99 .95"
It now outputs;"3743","187.80.037","Terral","010037420110","20","99.95","99 .95""3745","187.80.037","Terral","010037420110","20","99.95" ,"99 .95"The whole second line is different..
My example works correctly.
I got the output:
Yes, you can mail me your CSV files and the task, please, to oleg (at) robotask.com
rice1973
Post by rice1973 »
Hi,Found the problem!! By a strange way the import from the task "forgot/ did not import" all the "{EOL}" string, it shure is in the file.Typed them manually and query workx! Bug in the program?
Hm-m-m...
it seems, yes.
We'll investigate the problem.
