Assign variable VALUE to another variable
KeesB
Post by KeesB »
How can I assign the VALUE of a variable to another variable?
I want to assign Records(0) To LastNumber. The value for Records(0) is say 1357, but now it stores {Records(0)} in Lastnumber. Which works IF I keep Recordss, but I'd rather delete Records as it is a complex variable (and I only need that number).
Hope someone has a bright idea....
Use "Set variable" action
put LastNumber into "Variable name" field
put {Records(0)} into "Variable value" field
And check "Expand variable value" checkbox.
In this case the action expands the expression first and next assign the result to variable.
KeesB
Post by KeesB »
Thanks!! I missed the checkbox.
Once again, great support on a great product!
Kees
