Can’t press OK on Remove Variable
David W.
Post by David W. »
Hi,I just noticed that when I edit any 'Remove Variable' task action, I enter the variable name that I want to remove and press the OK button.  The button presses but nothing happens and the dialog just sits there.It appears to happen on ANY use of 'Remove Variable'.  I have tried it on a new task and on new task actions.Anybody see this happening?  Strange.Thank you.David
It's a bug
Thank you for the report, the patch will be released ASAP
Fixed. Download the patch here
David W.
Post by David W. »
wow!  thanks!Nice to know that my 240+ tasks and subtasks are in good hands!Cheers!-David
