How to "trim" a filemname before "-"
rice1973
Post by rice1973 »
Hi,How can i "trim" a filename after "-"?Example;3621-271.20.10_3.jpgShould transform to;271.20.10_3.jpgThe are mutiple files, the amount of numbers for the "-" can be 1,2,3 or 4. Different filenames that have to be changed in a specific directory.
You have to modify my previous task.
See below.
It trims symbols before "-" (including "-") and, next, removes "_"
CatID=INTEGER|839555382
ExternalName=STRING|"Task662"
ID=INTEGER|2002596499
LocalVariables=STRING|"OldFileName,NewFileName,Apos"
Name=STRING|"Trim before ""-"" and remove ""_"""
ToLog=INTEGER|2
Name=STRING|"File Loop"
date1=STRING|"20100105"
date2=STRING|"20100105"
destvar=STRING|"OLDFILENAME"
file0=STRING|"C:\incoming\*.*"
searchkind=STRING|"0"
subdirs=STRING|"1"
timesize=STRING|"0"
ActionID=STRING|"A_STR_POS"
Name=STRING|"STR Pos"
from=STRING|"1"
search=STRING|"-"
source=STRING|"{ExtractFileName({OldFileName})}"
variable=STRING|"APos"
ActionID=STRING|"A_STR_DELETE"
Name=STRING|"STR Delete"
amount=STRING|"{APos}"
from=STRING|"1"
variable=STRING|"NewFileName"
Name=STRING|"STR Replace"
mode=STRING|"0"
source=STRING|"{NewFileName}"
substring=STRING|"_"
operator=STRING|"1"
value1=STRING|"{ExtractFileName({OldFileName})}"
value2=STRING|"{NewFileName}"
message=STRING|"File {OldFileName} is renaming to {NewFileName} ..."
Name=STRING|"Rename File"
file0=STRING|"{OldFileName}"
mask=STRING|"{NewFileName}"
subdirs=STRING|"0"
rice1973
Post by rice1973 »
Thnx,Works again!
