Remove undescores from filename
rice1973
Post by rice1973 »
Hi,How can i remove underscore's from a filename?Example;3621-271.20.10_3.jpgShould transform to;3621-271.20.103.jpgThe are mutiple files, with different filenames that have be changed in a specific directory.
See the example below. It removes "_" symbol from all names of files in c:\incomming folder.
CatID=INTEGER|839555382
ExternalName=STRING|"Task908"
ID=INTEGER|146130647
LocalVariables=STRING|"OldFileName,NewFileName"
Name=STRING|"remove ""_"""
ToLog=INTEGER|2
Name=STRING|"File Loop"
date1=STRING|"20100105"
date2=STRING|"20100105"
destvar=STRING|"OLDFILENAME"
file0=STRING|"C:\incoming\*.*"
searchkind=STRING|"0"
subdirs=STRING|"1"
timesize=STRING|"0"
ActionID=STRING|"A_STR_POS"
Name=STRING|"STR Pos"
from=STRING|"1"
search=STRING|"_"
source=STRING|"{ExtractFileName({OldFileName})}"
variable=STRING|"APos"
operator=STRING|"3"
type=STRING|"1"
value1=STRING|"{APos}"
value2=STRING|"0"
Name=STRING|"STR Replace"
mode=STRING|"0"
substring=STRING|"_"
variable=STRING|"NewFileName"
message=STRING|"File {OldFileName} is renaming to {NewFileName} ..."
Name=STRING|"Rename File"
file0=STRING|"{OldFileName}"
mask=STRING|"{NewFileName}"
subdirs=STRING|"0"
rice1973
Post by rice1973 »
Thnx,It wokrs.
