Help with Excel extraction and input
snwskier2
Post by snwskier2 »
I'm having a difficult time figuring out how to do the below task.  Here is the scenario.I
have an database in Excel 'sheet1' consisting of properties and property contacts.  Each row contains a property and related contacts.    1. I
need to extract their "lastname" "firstname" "city" "state" & maybe
"zipcode" from Excel, find their contact information via Anywho.com,
  2. then paste the one or many results (i.e. name, address, and phone number) along with the corresponding Property "PIN", in a xls sheet2 same workbook.  2.5 there may be one or more than one related contact for any one property, all property related contacts are on the same row.  3.Needs to run until it reaches the last property PIN.Example (xls sheet1) PIN               lastname   firstname   city        state     zip     lastname2  firstname2   city21212123123    Doe          John        Chicago    IL      60601   Smith        James         PlainfieldI do appreciate any help, thank you.
I wrote small example (see below).
This task processes Excel table with 5 columns
You should select top-left cell and press Ctrl-Alt-J
The task put each value into variable and moves the selection to next cell. After 5 cells it moves the selection to next row and etc.
Then the value will be empty the task will stop.
Of course, you may change the Hot-Key and amount of amount of columns.
CatID=INTEGER|1380072790
ExternalName=STRING|"Task871"
ID=INTEGER|1483449583
LocalVariables=STRING|"a1,a2,a3,a4,a5"
Name=STRING|"Excel input"
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Action18=FOLDER
Action19=FOLDER
Action20=FOLDER
Action21=FOLDER
Action22=FOLDER
Action23=FOLDER
Action24=FOLDER
Action25=FOLDER
Action26=FOLDER
Action27=FOLDER
Action28=FOLDER
Action29=FOLDER
Action30=FOLDER
Action31=FOLDER
Action32=FOLDER
Name=STRING|"While loop"
value1=STRING|"true"
Name=STRING|"Copy"
mode=STRING|"1"
Name=STRING|"Get Text"
variable=STRING|"a2"
ActionID=STRING|"A_STR_TRIM"
Name=STRING|"STR Trim"
[Actions\Action12\Params]
custom=STRING|"0"
eol=STRING|"1"
lead=STRING|"1"
source=STRING|"{a2}"
spaces=STRING|"1"
tabs=STRING|"1"
trailing=STRING|"1"
Name=STRING|"Delay 200 ms"
[Actions\Action13\Params]
delay=STRING|"2"
[Actions\Action14]
[Actions\Action14\Params]
currentwindow=STRING|"1"
fixedwindow=STRING|"1"
keylayout=STRING|"0"
keys=STRING|"{RIGHT}"
sendkind=STRING|"0"
wincaption=STRING|"Notepad"
[Actions\Action15]
Name=STRING|"Copy"
[Actions\Action15\Params]
mode=STRING|"1"
[Actions\Action16]
[Actions\Action16\Params]
variable=STRING|"a3"
[Actions\Action17]
[Actions\Action17\Params]
custom=STRING|"0"
eol=STRING|"1"
lead=STRING|"1"
source=STRING|"{a3}"
spaces=STRING|"1"
tabs=STRING|"1"
trailing=STRING|"1"
[Actions\Action18]
[Actions\Action18\Params]
delay=STRING|"2"
[Actions\Action19]
[Actions\Action19\Params]
sendkind=STRING|"0"
Name=STRING|"Copy"
mode=STRING|"1"
[Actions\Action20]
Name=STRING|"Copy"
[Actions\Action20\Params]
mode=STRING|"1"
[Actions\Action21]
[Actions\Action21\Params]
variable=STRING|"a4"
[Actions\Action22]
[Actions\Action22\Params]
custom=STRING|"0"
eol=STRING|"1"
lead=STRING|"1"
source=STRING|"{a4}"
spaces=STRING|"1"
tabs=STRING|"1"
trailing=STRING|"1"
[Actions\Action23]
[Actions\Action23\Params]
delay=STRING|"2"
[Actions\Action24]
[Actions\Action24\Params]
sendkind=STRING|"0"
[Actions\Action25]
Name=STRING|"Copy"
[Actions\Action25\Params]
mode=STRING|"1"
[Actions\Action26]
[Actions\Action26\Params]
variable=STRING|"a5"
[Actions\Action27]
[Actions\Action27\Params]
custom=STRING|"0"
eol=STRING|"1"
lead=STRING|"1"
source=STRING|"{a5}"
spaces=STRING|"1"
tabs=STRING|"1"
trailing=STRING|"1"
[Actions\Action28]
[Actions\Action28\Params]
delay=STRING|"2"
[Actions\Action29]
Name=STRING|"Show ""{a1}"""
[Actions\Action29\Params]
msg0=STRING|"{a1}"
msg1=STRING|"{a2}"
msg2=STRING|"{a3}"
msg3=STRING|"{a4}"
msg4=STRING|"{a5}"
msgcount=STRING|"5"
variable=STRING|"a1"
[Actions\Action30]
Name=STRING|"Delay 500 ms"
[Actions\Action30\Params]
delay=STRING|"5"
[Actions\Action31]
[Actions\Action31\Params]
keys=STRING|"{DOWN}{LEFT}{LEFT}{LEFT}{LEFT}"
sendkind=STRING|"0"
[Actions\Action32]
custom=STRING|"0"
eol=STRING|"1"
lead=STRING|"1"
source=STRING|"{a1}"
spaces=STRING|"1"
tabs=STRING|"1"
trailing=STRING|"1"
operator=STRING|"7"
value1=STRING|"{a1}"
Name=STRING|"Break"
delay=STRING|"2"
sendkind=STRING|"0"
hotkey=STRING|"49226"
