read number from *.txt file
hufad
Post by hufad »
I need to read a number from txt file , compare it to another (*. mp3) and if equal, copy the mp3 to another folder
for example: if 15 is equal to 15.mp3 copy it to another folder (mp3 file)
I need to do this every half hour and if you go changing the new file, copying to another folder
Describe in more detail, please.
How look the text file? If it contains the number only, it’s very simple.
There is File Loop for this purpose. You may read the first line only, like this:
Text loop // and assign the variable
   break
End loop
After the loop the variable will contain first line of the text.
hufad
Post by hufad »
is fine, but as I compare with the file you have and copy to another directory
is to read the number (temperature) of this file (*.txt), compare con my mp3 folder if equal  copy my file to another folder to play
eg : extract  15 from *.txt  , compare con my folder, if exist 15.mp3 , copy it to another folder
(*.txt file has a two-digit number always)
is to use radio automation for saying on air temperature automatically
thanks,
It would be great if you send a few examples of text files.
