Pre Purchase Query
alexmuir
Pre Purchase Query
Post by alexmuir »
If I need to repeat a key for example I may need to Tab 4 times in a print window to set the number of copies  is there a way of doing this.
Or when in the Send key do I have to repeat the TAB key 4 times?
Thanks for your help
Pre Purchase Query
Just put into the text the following:
{TAB}{TAB}{TAB}{TAB}
Also see "Insert a key" button. There you can insert some key combinations from menu.
Also, pay attention, that you have to put some pauses between sending keystrokes. It's necessary to give some time in order the application could do the requested actions.
alexmuir
Pre Purchase Query
Post by alexmuir »
Thanks for your reply Oleg and your tip about pausing. In passing do you have a command such as {TAB}{4)?
Thanks for the fast reply
