Manual Update
waldo
Manual Update
Post by waldo »
Oleg,
Do you know if the PDF manual is also updated when RoboTask is updated?  While I know most of the items are bug fixes, I see that ver 3.5 has a new command [clip board get].  Looks like there was also a new command added in ver 3.4.  Are new commands included and documented in the manual as they are incorporated into new update releases of RoboTask?  Thanks.
Manual Update
Yes, of course. PDF manual is updated too.
"Clipboard Get" is not new action.
We have added the new feature into this action:
now it can retrieve the list of files from the clipboard. You may select some files in Windows explorer, copy them into clipboard and you can retrieve the list of copied files in RoboTask and save the list into variable.
Yes. New chapters in manual:
Debugging of the task
Peculiarities of working in the system service mode (and subchapters)
Unique File Name (action)
Run Program as User (action)
Changed chapter:
RoboTaskApp object
waldo
Manual Update
Post by waldo »
Oleg,
Thanks for the clarification.  I hope RoboTask users appreciate this attention to documentation detail because it is the exception rather than the rule.  I prefer to print the PDF manual to use it as a reference book when I am working with RoboTask rather than trying to have a second window open to display the manual.
I was already to print the pdf manual, but I didn't want to waste paper should it not be updated to reflect version 3.5.  Again, I can't praise you enough for this attention to detail...thank you.
Waldo
